OK, I'm not 'new' to this as such, just new to this forum. I'm a regular member of the UK GT4 owners club but I dont seem to be able to get an answer to this question from there so I thought I'd post it here in case you lot had an ECU genius amongst you. For the record - running a basically stock 185 on 12-14 psi with relief valve boost control and stock everything else.
From everything I've read online, the MAP sensor on the 2nd gen 3sgte (ST185, non RC or carlos) has nowt to do with fueling, it serves only to allow fuel cut and the work the pretty (useless) dash boost gauge. Unlike the ST205 which uses that instead of the flappy AFM.
I've been having some jerky acceleration and deceleration problems with my car, and not been able to track it down - plugs and leads are ok, dizzy and rotor seem fine etc etc. Checked all sensors like the AFT, temps, throttle position sensor etc - all within spec. So in a last ditch attempt I started pulling connectors off things of lesser importance to see if i had a fault on any of them. Dropped the boost to stock - no change. No codes present at any time.
So i whipped off the electrical connector to the turbo pressure sensor (left the hose on) and that instantly cured my 'stepped' acceleration and hiccuping deceleration. It also gives me better 'pull' in high gears.
This tells me that the Turbo PS either alters fueling, timing or some other vital parameter.
I dont want to leave it off - no fuel cut if the boost control goes badly wrong, so i'll have to get a new one, but the key issue is that everyone ive spoken too was under the impression it made no change to the anything unless you hit a threshold for fuel cut.
Thoughts?
James
Thoughts?
James
