Does anyone know of what you are suppose to use to lube the track that the auto seatbelt moves on? Any help would be greatly appreciated!
+1timebuilder said:The thing I like most about the silicone spray is the lack of a physical residue as I would find with conventional grease.
The previous owner of my wagon put some grease on the belt tracks. The grease dried out later and caused noise and wear on aluminum track plate. Therefore I would not encourage greasing of the belt slide.
What are the different properties between multi-purpose grease and lithium based grease?The first owner probably used wheel bearing grease.
