From that last sentence, you sound like a former Chrysler owner. :lol:
Not only should you charge the battery, but you should take it to a store and have it tested. Some batteries can appear to have a full charge, but be able to deliver so little current that it cannot crank even a small four cylinder motor. This past summer, I had a set of jumpers on my dad's caravan battery and could not get more than a few degrees of crank rotation. A trip to Pepe's for a new battery and it started like a formula one engine.
Test the battery with a load or conductance tester before you take your next step. Obviously, if the battery fails the test, leave it there and come home with a new battery. The right type battery will have the toyota positive terminal fit up nicely. The wrong type will not.
