1 - 3 of 3 Posts
GT-i Crew
No you can't. Its like using a Sony TV remote control on a Sharp TV. Each ECU is programmed according to a single engine model.
If you want to get it to work properly get yourself a 3S-GTE because there is NO WAY it's going to work like it's supposed to.
I don't think the plugs are even the same. On top of that, the 3S uses different impedence injectors and its a true Twincam vs the 5S scissor gear setup. It can be made to work, but theres absolutely no point, as stated above.
1 - 3 of 3 Posts
