1 - 9 of 9 Posts
i have a 91 celica gt w/turbo swap and the exhaust manifold glows bright red after a 10 min drive the car does not read hot on the temp guage there is no thermostat just a restrictor plate did coolant pressure test no leaks
also ran compression test cylinder 1. 180 2. 180 3. 160 4. 160 and also have bubbling sound in overflow tank but am running staraight water
'91 MR2 Turbo
Note:Remember, gutting your cat is illegal.
BUT, if you do, you will see a faster spool and alittle more HP.
Remember to wear a particle mask and eye protection. The dust from the Cat material is very harmful to your lungs and eyes.
Ultimately, the best solution is a new catless exhaust system-from the turbo to exhaust tip exit.
yeah MR2jedi is right it is illegal in most areas im not sure whether it is here or not but the dont check our cars so untill they do ill be running a gutted cat i need to go ahead and get it dont to my celica before i forget about it
If you don't want to run without a cati, get yourself some acetone cut the cat off the pipe clog one end pour the acetone in and slosh it around for a bit, tip it like a rain stick. pour it out on a stump or something, your cat should now be carbon and oil free.
1 - 9 of 9 Posts
