1 - 3 of 3 Posts
Hello i have a 91 xorolla 5spd with 113k and when i take off i feel like vibration or shutter between 20 and 30 mph in secons and 3rd when catching up to speed. If i remember when you go up hill. Anyone had this problem?
Sent from my LGMS631 using Tapatalk
1991 Toyota Corolla,
Could be alot of things. Are you sure the clutch isn't slipping? I've seen slipping clutches shutter under load. Also could be bad motor mounts.
Reactions: kobej05
Discussion Starter · #3 ·
I have to check if it stays shuttering at 30 mph. How so i test the motir mounts to see if they are still bad? I put a jack last time on my 95 and the vibration went away. But i have no vibration when starting it.
1 - 3 of 3 Posts
