My 91 mr2 non turbo runs great but after driving it for about 15 miles it will stall and won't restart for 5 to 10 minutes. This is very frustrating because I work on a military base and the gate is right at 15 miles away and today it stalled right as I got to the gate causing a little bit of traffic to build up behind me. When it stalls the check engine light and a couple other warning lights come on. It will turn over but seems like the engine isn't getting any fuel. I have read the other threads where people report similar problem but nothing seems to be the same. I live in the desert where it is very dry and cold in the mornings. Once the engine stalls and is restarted the problem doesn't reoccur. It only happens once until the next day. It holds its RPMs just fine and doesn't seem to be anything related to where it idles. I ran a fuel cleaner through it and the previous owner changed the ECU and ran Sea Foam through it to try and fix the problem but didn't work. I am going to change the spark plugs today to see if that helps but I am stumped. My dad thinks it sounds like vapor lock but that usually happens when it is hot outside and the temp is around 30 degrees. If anyone has had a similar issue or knows what might be causing this I would really appreciate the advice.
