1991 standard cab pickup, 5-speed, 22re engine, 349,000 miles. The truck has episodes of rough running/missing that can be severe. The engine may quit without warning. When it does, I turn the key off, then on. It immediately restarts and I continue driving. Trouble code 14 was first noticed in 2008 and always returns when cleared out. It has been in three shops, five times with no help. Work done to date: Plugs, wires, distributor cap, rotor (2000, 2008), new oxygen sensor (code 21, 2008), new fuel filter (2008), new fuel pump (2009), new ignitor (2009), new coil (2009), rebuilt distributor (2009), new coolant temperature sensor (2009), new vacuum modulator (2010), replace vacuum tubing (2010, new battery cables (2010). Cleaned throttle body (2009), cleaned EGR (2010), removed and tested TVV (ok per fsm). Got two used ECU's, truck runs same with any one of three installed. Truck always starts ok. Problem can be intermittent. Drove to work this morning (90 miles) with occasional minor missing. Last Friday it shut down 32 times in first 30 miles with severe missing all the way.
