no spark
Did u pull your Dist. cap to see if your rotor is turning ?
Short guess if you are getting fuel (seeing you already checked spark) is the timing chain if 22RE and Chain if V6
:thumbsup:Did you replace the coil with the igniter. Also check the lead that goes into the distributer. It is what the igniter connect too. If that is bad, you may have to replace the distributor or distributor housing. That is the only way to get that part inside the distributor.
