1 - 4 of 4 Posts
A few things are different but finally got it in there. Question is, what's the secret to getting steerring gear back in at the top knuckle. It has a pinch bolt top and bottom of knuckle. No problem with bottom nearest gear but the top where it fits into steering colum shaft wont slide in all the way to get pinch bolt in
3s-gte in a Camry?!?
'89 Camry Alltrac
No secret. I think I went on to the steering shaft first, then down onto the rack. You may need to pry open the opening on the joint.
-Charlie
I finally figured out why flywheel to TC bolts wouldn't torque! They changed to M9 in 1990 another strange Toyota scheme is that one of the 6 bolts is longer than the other 5. Where does the longer bolt go? 5 are 12.8 and the longer one is 12.9. That's strange.
1 - 4 of 4 Posts
