91 truck oil leak
900 Views 1 Reply 2 Participants Last post by  brokentoy
I have a 91 pickup 4wd V6 engine with a bad oil leak from the front seal area. I am guessing it is the seal and looking for advice on changing the seal. Can I get the seal out by prying with a screw driver?
Also thinking of drilling the seal and inserting a sheet metal screw to pull on or maybe I have to buy a slide hammar.
Can I install the seal using a appropriate size sccket and tapping wioth a hammar ( my usual method of seal installation)
Can the oil leak be from somewhere else (commonly)
Thanks in advance.
1 - 2 of 2 Posts
either method should work man, it's gonna take paitence though, kind of a tough place to get to. check the crank for scoring, you may need to speedy sleeve it
1 - 2 of 2 Posts
