1 - 2 of 2 Posts
92 4runner SR5 V6 3.0L EFI auto transmission
The motor has been rebuilt, transmission has been rebuilt too. It was dying when I'd stop, but not every time. Had vacuum hoses changed too. I could drive it around and it would die after awhile. I changed the air intake hose/boot because the other had small crack in it. I thought that might solve the problem but it seemed to make it worse. Now when you crank it white smoke will sometimes comes from tail pipe like it is flooded, it runs rough and dies. I am going to check my PCV valve and change it out. Hope it helps, anyone with ideas or similar experience.
Soylent Green sales
rock crawler
Have you checked to see if any CEL codes have been set?
How much white exhaust? A lot of sweet smelling white exhaust means you're burning coolant.
1 - 2 of 2 Posts
