Some engine wear? A 60psi (170 down to 110) is a ton of wear. At around
90 psi it's gets real hard to get gas to burn.
If the engine is in fact at around 110 psi compression, then the rings or
valves are shot. I am really questioning if the compression tester is bad
since all cylinders are around the same level. Normally, you will see one
cylinder go fist and loose compression.
And 110psi is not normal for an engine with 157k miles unless it's been
run without an air cleaner. I have 337k on my 3L engine and the compression
is around 160 psi.
I suggest Mudduck have a dealer to a second compression check.
On Thu, 26 Jan 2006 11:32:25 -0800, MrFixit469 wrote:
> The compression reading just shows there is some engine wear, normal for
> an engine with 157,000 miles! The thing to look for is one cylinder to
> be drastically different from the others, which there isn't. The
> compression is OK! Look somewhere else. Bad spark plugs, plug wires,
> distributor cap. Yes, it's possible to buy a bad new spark plug, it only
> needs to be dropped once to crack the insulator and cause an ignition
> short. Have you had the igniter or ignition coil checked? Most parts
> places will check these for free.
