I have a '92 Camry with roll-down windows, and the speaker locations are for 4" drivers. The speaker mounts in a plastic piece that raises it so that it doesn't hit the window. The opening the plastic piece screws into is oddly shaped. Other Camrys from the same time (that had power windows) had 6.5" speakers, also in a plastic bracket. My question is, if I get the plastic piece from a higher trim level Camry will it screw into my door and can I use it to put bigger speakers in? Or am I stuck with 4"?
Thanks,
~Eric
(I also posted this in the Camry forum, apologies if that is bad form)
Thanks,
~Eric
