1 - 6 of 6 Posts
96 3MZ M/T
Camry
sounds like it might be something with the high/low pressure switch ... how cold is it you might be low on gas or the dryer might be bad ... also the off chance the expansion vlave might be a little cloged
Mad Scientist
94 scepter coupe
it could be a number of things:
belt worn and is slipping
freeon is low
ac compressor is going bad
oil leak affecting the compressor belt
find the pressure switch and disconnect it the bridge it with a paper clip and the blinking should stop if it cools then your freeon is low and/or leaking
99 Camry
The expansion valve is a known issue with Gen 3s. Mine went out about two years ago. I know it requires the freon to be removed, so you'll probably need to take it in to a shop.
-Joel
1 - 6 of 6 Posts
