1 - 4 of 4 Posts
Hi all,
92 Camry Le 2.2 litre automatic.
Started right up this am , and ran great for a half minute or so, backed up 10 feet and it died, I tried 3 or 4 restarts, nothing at all, no hint of starting, just cranking over at regular cranking speed.
I might have been out of gas, the tank said 3/4 full but as I recall it's been reading that for a while (several days).
It might have been out of gas, my buddy brought me 3 gallons to put in this afternoon.
Cranked it 5 or 6 times, nothing again.
I pulled off what I think is the intake hose, (2" + diamater) , opened the butterfly and squirted a couple good squirts of starting fluid in it.
Cranked but once again didn't even hint at starting.
Checed the fuse to the fuel pump , seems good.
Any ideas would be appreciated.
Discussion Starter · #3 ·
Check for spark at spark plugs. Pull distributer cap and see if rotor turning on attempt start to determine if timing belt broken.
My tools are at work , I'll pick up some tomorrow, I don't even have a phillips screwdriver here....
I pulled off one spark plug, when it gets dark I'll crank and see if I see a spark.
Tomorrow I'll take off the cap and see if the rotor turns.
Thanks.
1 - 4 of 4 Posts
