I have a 1992 Camry, 4cyl. manual transmission. I replaced my radiator, making sure to reconnect everything, and my fans don't work now. When I turn on the A/C, the temp gauge rises after a few minutes, but the fans won't kick on. Any ideas?
I have a 92 4 cyl manual also, and my fans come on as soon as i turn the A/C on, so u might have motor problems or fuse problems. Check them both, get a light tester, and check for power on both motors. then check the fuses.... could be anything.
ok i have noticed that my fans never seem to come on.. maybe while im driving.. but I never ever hear them come one when the vehicle is turned off... shouldn't they be turning on? Especially when the temp. is above mid-range on the guage? Hotfix?
Both fans should be running with a/c. I am pretty sure you didn't put the plugs back in tighten enough. Check this, especially the one on the left side (when you are in front of the car) : just push as hard as you can and put some wd 40 before.
