Recently, my 92 corolla trunk lid wont close and latch. I had to slam it really hard one time, and then it wouldn't open with the key or cable thus had to unbolt latch from the car. Note: Nothing wrong with the key, but neither the key nor the cable would let the trunk unlatch.
The latch mechanism will work when off the car and can be unlatched manually. The latch mechanism was lubed up and reattached to car. The metal latch finger moves to the position that it would be in when closed and will move to the open position when the cable is pulled or with the screwdriver. The finger activates when closing the trunk lid but will not grab the trunk latch.
I tried to adjust the latch and the metal attachment, but there is no adjustment i.e. up/down or left/right to allow one to adjust the latch its fixed. I may need to use a breaker bar to adjust the metal plate or cut some slots into the bolt holes for the latches metal part that the hook grabs onto and the lock mechanism itself that bolts onto the car.
Any other way to adjust the lock/latch mechanism in this 92 corolla?
