Theres 3 belts. 2 accessory belts and a timing belt.Lostboy said:
You can't see the timing belt. Its behind a cover.
One of the accessory belts go around the crank pulley, alternator, and a/c compressor (if you have a/c). The other accessory belt grounds around the crank pulley and power steering pump.
Not sure what they cost.
Goto a autoparts store and ask them for hood struts.
