1 - 3 of 3 Posts
I need HELP. I have a 92 Paseo with 342k. Still gets 40+ mpg, 5 speed with lots of pep and like to burn oil.
It has began to studder at speed, RPM's don't seem to change and will continue to drive. Recently, the RPM's take a dive when coming to a stop and will die. Usually can restart after a moment or two ( smell of gas strong) then drive on without much issue. Issues are more so once it's warm, when cold idles fine. I have already exchanged the IAC, air intake, searched for leaks, new fuel pump, exchanged entire distibutor unit, new plugs and wires. Fuel pressure regulator and ICM seem to be only things left. I know where the FPR is but having a hard time locating the Ignition Control Module. Open to ideas and suggestions!
So most likely the cause? I don't see how the FPR would be it or block temp sensor either. Just ready to put some miles on her.
1 - 3 of 3 Posts
