1 - 17 of 17 Posts
hi guys i have 92 paseo and the block is shut i was wondering if my 1991 tercel block could replace the paseo broken one or i should find onother paseo block tnx anyting will help
Got a FC3S!
92 Paseo/90 RX7
tercel block will work, but youre better off with another paseo one
Yep, just so you don't have to worry about anything being different. I think they are 99% identical, maybe a sensor harness here or there different, but identical in every other way. This is assuming that you are going junkyard for the block. If getting a new short block it won't matter, because it won't have anything from an old SOHC set up on it.
Got a FC3S!
92 Paseo/90 RX7
Tercel
I had to remove the cylinder head on my 91 Tercel and didn't feel like paying $45 at a dealership for the part. So I found a JTC 1936 SST which fits the head bolts perfectly and worked absolutely great for getting them out. it cost me $21 shipped.
Discussion Starter · #12 ·
so now i have a new problem i got a new long block i put it in and started the car today it started and ran less then a minut and shut off what could be the problem could it be the timeing belt or i dint conect the engine with the transmishon the right way its automatic any help will be good tnx agen for all the help
Tercel
hey so if i use tercel block i should get paseo pistons and other thing do i use the paseo head gasket or tercel
if you're using a 5efe head then I'm almost positive you have no choice but to use 5efe pistons and other parts...I think you can still use the 3e block though(i'm pretty sure its the same as a 5efe block). As far as the gasket goes I'd use the 5efe head gasket.....do your homework first and don't take my word as the end all.
Disclaimer: My advice is just that, nothing more. Please, Please, Please do your homework first and make sure everything is going to work. I claim no responsibility if my advice gets you killed, maimed or injured in anyway. Same goes for your car. :)
1 - 17 of 17 Posts
