2-23-05 Generally, you remove the knobs by pulling out on them. Then,
using a small hook in the slot, pull the right side out gently.
Usually there are two clips and it is hooked in on the left end.
Sometimes crutchfield has tips on removing the dash. Good luck. Ed
