Hi all
I am new to the forum and am running out of ideas. I have the above mentioned vehicle. It is a Jap import into Aus and has the 3S-GE engine in it. Up until the other day it ran like clockwork.
I have only just purchased it and decided in my wisdom that I wanted to give the engine bay a really good pressure clean. I dried it all off and it was ticking over nicely until I decide to put some revs on it. It will only rev to around 2400 rpm and then hunts up and down like a fuel cut is running. It isn't missing and idles just fine. I dried everything off that I could think off or see, igniter, coil, dizzy, throttle pos sensor, air bypass... you get the idea. Either way it still does the same. I took it for a run on the road to try and get some heat into it thinking that this is a water issue. It ran like a rocket until I pressed the overdrive button on the auto and then it started to hunt again. Pressing the button will make it run fine, or not. I thought it may have a failsafe on the auto that sensed low oil level. Checking the auto revealed low oil and I topped it up. Took it out on the road again, same thing. Sitting in the shed, I can plant the boot to the floor and it will hunt.
Went to the local Toyota shop to see if they had encountered this and they hadn't. I am lost, I spent 5 years working as a Toyota Tech and never came across this issue.
Any ideas? There aren't any ECU codes, I have disconnected that battery for hours and tried again. Nothing. I need a fresh approach.
Thoughts?
Thoughts?
