1 - 4 of 4 Posts
B
Guest
V6 Standard. 10 amp gauge fuse out resulting in gauges, heater fans,
driving lights, moonroof and power windows all out. Replace fuse
results in burn out in five second. Any suggestions would be
appreciated.
R
Guest
Discussion Starter #2
"buddha2948" <[email protected]> wrote in message
news:[email protected]
> appreciated.
If there was a dead short in the circuit, the fuse would blow immediately.
Since it takes 5 seconds to blow, I would suspect a hot wire making
intermittent contact with ground or a high draw somewhere. I'd start with
stuff that has a fairly high amperage draw to start with like the heater
fan, driving lights, mooonroof, and power windows. Start with anything that
is aftermarket or that has an aftermarket accessory tapped or mounted
nearby.
Ray O
B
Guest
I forgot to add this information in my original post. I have noticed
some smoke coming from just behind the engine, low on the firewall. It
appears when I put a 10A circuit breaker in place of the fuse. Do you
know what could be in that location. Thanks for the info
R
Guest
the heater blower and heater resistor may be in this location. Obviously,
smoke is an indication of something burning, and the blown fuses are
preventing the problem from becoming worse. I recommend that you remove the
circuit braker and get it fixed ASAP before you really have a problem!
Ray O
1 - 4 of 4 Posts
