1 - 4 of 4 Posts
Hello, My rear wipers in my Camry stopped working. I have checked the fuse in the driverside dash, its good and I think its for the front wipers only. My manual doesn't state if there even is a fuse for the rear wipers. Is there something else I should check?
Thanks
Mark from Colorado
The Camburger
Perhaps the motor has worn out, it is 11yrs old. Don't know how you could test it though. try a replacement at a junkyard maybe:confused:
Mad Scientist
94 scepter coupe
remove the cover that blocks the motor off and unplug the connection to it.
then get 2 wires and run power straight to the wiper motor it might just be stuck(mine was that helped it)
this usually happens when something doesn't get used at all.
Discussion Starter · #4 ·
Thanks will try that wickedtoyz the camry used to live in st george utah don't think the rear wipers got used that much ...thanks again
1 - 4 of 4 Posts
