About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-36.htm
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-53.htm
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-71.htm
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-90.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Engine.html
http://www.mad-mechanic.com/toyota/toyotaobd.shtml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota
http://members.igateway.net/~pscott/enginecodes.html
http://www.autobook.co.kr/data_links/toyota_trouble_codes.htm
http://www.autoshop101.com/forms/h27.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp
1985 Toyota 4-Runner/pickup Factory Service manual:
http://www.jasuza.com/1985toyotatruckfsm.pdf
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mechanical/96TacomaDiagrams/index.htm
http://perso.wanadoo.fr/adherence.4x4/liens_techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/automotive/toyota.manuals
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://aarc.epnet.com/application/8578/8578.htm
http://aarc.epnet.com/application/9316/9316.htm
(1997–2000=4-Runner,pickup,T100,Tacoma,Tundra,Landcruiser)
http://www.bedlib.org/ebsco.html
then click on “AARC” or “Auto repair reference center”
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:
[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
