Your front crankshaft oil seal has worn and worn a hole in your crankshaft you can either purchase a thin 7mm seal and place it over a different position or use a speedy sleeve,read below:
Harmonic balancer repair sleeve/speedy sleeve (seal saver sleeve, balancer repair sleeve,crank seal saver,sleeveNseal ring) slides over shaft:
Felpro # 16214=$5
Future # 21-2514 (aluminum shaft sleeve included)
NAPA repair sleeve # 99177 (Mack PDC,National,Car Quest)
Pioneer repair sleeve (Silver Seal) # HB-4133
CS4128
attached with some epoxy or use Loctite 609 or 242 or put some red RTV and fill that groove before you put it on also look in the yellow pages under “bearing suppliers”.
For a picture:
http://chicago-rawhide.com/auto/speedi/speedi.htm
For seal replacement step by step process:
http://www.barneymc.com/toy_root/techneek/frntseal.htm
Front crank oil seal (front input shaft seal):
Fed Mogul (National,Timken Seals) # 710345
Toyota # 90311-45014 (brown, 7 mm thick) & 90311-30115, Chicago Rawhide # CR17758 (9 mm thick) or CR550294 (7mm thick)
Beck Arnley # 0522144
Victor Reinz # JV912= NJ243=Toyota # 90311-45069 (for 1981 Toyota with 22R)
NAPA repair sleeve # 99317(rear),list price $68.10>$33.19 net Canadian $ and the seal was $12.10
There are 3 versions of the speedy sleeve:
1)one is light steel with spray chrome flashing(yuk)
2)one is steel with chrome plating
3)and the good ones are all stainless steel and they are made in Canada.
In North America the 22R & 22R-E s are used in the following:
22R
1981-82 Toyota Corona
1981-83 Celica
1981-87 Toyota pickup (up to 1990 on 2wd)
1984-87 Toyota 4-Runner
22R-E (22REC=California emissions=extra charcoal canister)
1983-85 Celica
1985-95 Toyota pickup
1985-95 Toyota 4-Runner
22RTE (Turbo EFI)
1985-87 Toyota pickup
1985-87 Toyota 4-Runner
Any Public Library in your area would have the Factory service manual, Haynes,Chiltons,Mitchells,Clymers, Bentley and Toyota repair books.
Free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp
Tons of free factory service manuals for 4-Runners,etc:
http://www.ncttora.com/fsm/index.html
http://rapidshare.com/users/4NH9R4
http://forum.ih8mud.com/showthread.php?t=128021
http://www.babcox.com/editorial/ic/ic110028.htm
Free 1985 Toyota 4-Runner & pickup Factory Service Manual:
http://www.functionalfab.com/resources/toyota 4runner.pdf
http://www.ncttora.com/fsm/1985/1985FSM.pdf
http://www.muchadoproductions.com/info/xxx1985toyotatruckfsm.pdf
http://www.truckporn.com/tech/FSM/Toyota/1985fsm.zip
http://s3.uploadline.com/d/4831811/1168232885/1985fsm.zip
http://www.lukemiller.org/toys
http://www.subliminaltrips.com/1985toyotatruckfsm.pdf
Free 1988 Toyota 4-Runner & pickup Factory Service Manual:
http://granolaboy.net/temp/toyota_truck_and_4runner_88.pdf
Free 1993 Toyota Pickup Service Manual:
http://www.ncttora.com/fsm/1993/index.html
http://personal.utulsa.edu/~nathan-buchanan/93fsm
http://www.ncttora.com/fsm/1993/1993.zip
http://www.snjschmidt.com/wiring
Free 1995 Toyota 4-Runner Factory Service Manual:
http://www.the-roo.com/4runner
1996 Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
http://www.ncttora.com/fsm/1996/96_repair.zip
http://www.ncttora.com/fsm/1996/images/index.jpg
1998-2000 Toyota Tacoma Factory Service Manual 5ZE-FE:
http://www.ncttora.com/fsm/2000/index.html
http://www.ncttora.com/fsm/2000/2000_FSM.zip
2003 (years: 2001-2004) Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
http://www.deserted1.com/FSM
http://www.ncttora.com/fsm/2003/index.html
http://www.ncttora.com/fsm/2003/2003_FSM.zip
2005-2006 Toyota Tacoma Factory Service Manual 1GR-FE & 2TR-FE:
http://www.ncttora.com/fsm/05+/index.html
http://www.ncttora.com/fsm/05+/05+_FSM.zip
Free 1989 - 1995 Pickup Mitchell Service Manual:
You can download the winrar archiver from:
http://www.rarlab.com/download.htm
And The ISO file can be downloaded from:
http://www.filecrunch.com/file/~ga05yg <--- Part 1
http://www.filecrunch.com/file/~tlgobs <--- Part deux
The two rar files are 90 Megabytes in size, but once unrared it is a 300 Megabyte ISO image.BTW: File will be removed automatically if there is no download for 30 days.
FSM (factory service manual) & owners manuals can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton, CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers, websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
:worship:
Sidney® ™
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
:kingme: for I am :canada:
