1 - 7 of 7 Posts
L
This appears to be a very common problem with 90's camry's and I wanted
to post how I fixed the problem. I tried a couple of mechanics and none
were able to diagnose the problem. Fortunately a guy on the UK toyota
owners group figured this out. His name is Ive and he is from British
Columbia (just wanted to give him credit). His mechanic found the
problem by running diagnostics on the car as it was running.
The symtoms of this problem are that when the car is started and is
cold the car runs fine. Once the car warms up a bit it will stall
whenever you stop. Also some people complain that they smell a strong
odor of gasoline.
The problem is the coolant temperature sensor. These are consistently
fail in 90's camry's. When I went to the toyota dealership and asked
for a coolant temperature sensor the parts guy gave me this exploded
parts diagram of the engine that showed about 10 sensors that were
abbreviated. That confused the hell out of me. So I went to a local
parts store called VIP auto. They were very helpful. I told them I had
a 94 camry wagon 4 cylinder and they ordered a KEM brand coolant
temperature sensor part# 140-715. $35 part. I figured it was worth a
try.
This is how you find the sensor. Under the hood, top of the engine,
next to the valve cover, a little bit towards the driver side is 3
different sensors. Quick connect wire couplings come off the top of
each sensor. I figured out which sensor it was by looking at the
connector on the replacement part. On my car it was the sensor closest
to the center of the car. Squeeze a clip on the sensor and the coupling
comes apart. The sensor threads into the coolant output line coming out
of the block of the engine. I used a 3/4" box wrench to loosen the
sensor. Since the sensor is above the rest of the coolant system,
barely any coolant comes out of the pipe AS LONG AS THE CAR IS COLD.
Out with the old, in with the new and my problems are completly solved.
This is a brass sensor so don't overtorque it. Just get it snug.
I was so appreciative of the guy who posted the fix, I felt it was my
duty to post the fix for more people on google groups. I hope this
helps some people like it did for me. Good LUCK!
J
Guest
Discussion Starter #2
<[email protected]> wrote in message
news:[email protected]
> odor of gasoline.
> try.
Glad you found it. Try buying a Haynes manual. It will provide info as to
where the various sensors are, and takes the mystery out of it.
I'll remember that one if my '96 4 starts doing anything similar. I've had
this car for 21/2 years. Its got 175,000 ks on it now. I put 20,000 on it.
It has not played up once except for a split CV boot. Great cars to drive.
Jason
M
Guest
Usualy a dirty coil from oil seeping by the O ring causes that, but good
to know you fixed it.
D
Guest
Thanks for posting.
No problem but will keep in mind for my '94
Just curious, had you kept factory coolant and distilled water fresh in
yours?
D
Guest
By the way, sometimes dealer parts people can be less than helpful.
They're supposed to assist you not make the identification more
difficult.
Some are much, much better than others.
The current person at my local dealer has given me so much
misinformation that I no longer believe anything he tells me - but in
the past, the parts people there were excellent.
1 - 7 of 7 Posts
