1 - 18 of 18 Posts
'96 Camry XLE
mandyfig said:
S2000 Rocks!
No mess with frozen antennas.....do you not hate it when it is stuck frozen?
S2000 looks cool, too.
I never did see yours completed! Any pics?
Lost to follow up!
96 Camry Coupes
Had to fix mine again today....just stopped midway, the cable thing became bound up in the motor, not sure why?...but I got it working again, had to take the cover of the motor over and over, couldn't seem to make it catch!......That S2000 antenna is looking better every minute!
I need more information on getting one!
I know parts!
isn't it just normally the mast that goes bad?
not the motor?
I only ask because mine doesn't work and it looks like the top section is missing (cable normally attaches to it)
'96 Camry XLE
not the motor?
More times then not, it is the Antenna that goes. I did the S2000 when my motor went. :lol:
Lost to follow up!
96 Camry Coupes
not the motor?
My motor worked fine, the cable broke! (1st time)....Yesterday I noticed it was up again, you would hear the motor run for just a second and stop...thought the motor went bad, When I took it apart the cable had become bound inside the motor somehow:eek: So I removed it and the motor was fine, then I had to get it to feed inside again, had the wife turn the radio on and off for me, cussed alot:hammer: Took the motor apart like 5 times before i could get it to work...it would go in so far and jam again!...finally when I was ready to throw the fucker over the house:lol: ..It fed all the way and is working OK for now!....I'm pretty sure its going to stop working again!
So would this mod work for a wagon? Been dealing with a broken mast and had planned to get one from a junker, but after reading this I'm not so sure that's a good idea. Being unfamiliar radio waves, would the antenna, being so close to a taller part of the car, not get reasonable reception?
Thanks
James
'96 Camry XLE
It MAY work, but the reception would not be good at all, bcause of the reason you stated. :(
1 - 18 of 18 Posts
