i just bought a non running paseo for 200$ it turns over, gets gas and gets spark. but i can tell it recently had the timing belt changed the guy said it ran after the timing belt went but then the fuel pump went, i replaced the pump. and still no running so i checked the timing marks on it and they were set to 10 degrees so i set it back to zero so see if that would do it and still no go. Im going to try to just start it agian thismorning and see if its just flooded or hydrolocked, but does any one have any ideas? can i test the timing with a timing light when just cranking the engine (i cant check it when idling cause it wont start) Your help would make me a very happy man!
