1 - 3 of 3 Posts
Hi All,
I am trying to clear the notorious code 25 on my V6 4runner. Did a full tuneup, used redline S1 fuel injector cleaner, compression test came back clean, replaced O2 sensor. Does anyone have an idea of what I should do next? Should I get a new MAF(had a shop test the current MAF and it looks ok but it is old) or replace the fuel injectors?
'94 Pickup/'96'rolla
I think you should just keep replacing parts until the problem goes away. :lol:
Why would you replace the air meter if it tested good? What makes you think the injectors are bad? Have you checked any of the other areas that the manual suggests for a code 25? Is the code coming back after being cleared?
· Languishing in Virginia
1994 XtraCab 4x4 P/U
There have been about 3 different threads opened here on code 25 in the past couple of days. Check those for more info.
1 - 3 of 3 Posts
