1 - 8 of 8 Posts
I recently inherited a '94 4 cyl sedan with the stock 14 inch steel wheels. The tires are pretty much shot and I'm looking to replace them. Locally there is a set of 5 wheels and tires off a Solara (no year given). The tire size is 205-60-15. They are just outside the recommended 3% larger size but are quite a bit wider than the stock 195-70-14s. I was wondering if anyone else is using this set-up and if I could expect problems with rubbing. I'm a new guy here and will probably be spending alot of time till get the car the way I want it. Thanks in advance for any help :).
Discussion Starter · #3 ·
I've looked through all the DIY stuff but I can only find info on tire diameter. The ones I'm looking at are slightly above the max recommended up-size of 3%. I'm more worried about the width. I seem to recall reading somewhere here that Solara tires will work on my car but, for the life of me, I can't find that post now. Anyone with any experience with Solara tires and wheels on a Gen 3 sedan?
· I HAS BOOST!!!
94 Camry SE V6 Coup
thoes wheels and tires will be fine. alot of camry models came with that exact size, msotly just the V6, but some 4cyl models as well. 15" wheels with 205/60/15s.
I assume they are 1st gen Solara wheels.
Do you mean 205/60R16? That's the tire size that came with 16" Solara wheels like these. 205/60R15s would be almost right on in terms of diameter.
1st gen Solaras also came with 15s. Those came with 205/65R15 tires on these wheels
Discussion Starter · #6 ·
Tom. You are correct...I meant 205/60/16 and they are exactly like the first picture you posted. It looks like the general concensus is that they'll fit so I'll be picking up a set of 5 this weekend. Thanks to everyone for all your help.
1 - 8 of 8 Posts
