I have a 95 4runner that has been very reliable up until now. I went to go to work the other day and turned on the key only to hear the dreaded 'click,click" I assumed the battery was dead so i jumped it and while I was letting it charge back up I noticed my engine was idleing rough. Upon further investigation, I noticed the voltmeter gauge was fluctuating slightly, then i went to use the power windows and locks and that dramtically affected the volt meter drop off. Also I took it for a drive and when i tapped the brakes the idle/tac started jumping around erratically. All this started at once after it sat for a day after i got home from work. Anybody have any idea what might of happened. As for the battery being dead, it starts sometimes now and sometimes it just clicks when I turn it over. Also the dash lights will dim when I push the power window or door locks buttons!
Totally confused!!!!
