-because I am buying really cheap from a friend...mort27 said:why would you want to do that, your only gaining 10hp and 10ft lb torque?
You have a 3ee. the engine you want is a 5e, direct drop in No physical mods needed your axels and even transmission are fine. you can use your old harness but I would really recommend getting the 5e ecu. Contact Dr tweak over the private messenger, He's one of most knowledgeable here on swaps. good luck.goalhan said:-because I am buying really cheap from a friend...
Tercel Drifter,
-what do you mean by rewire? Would I still used the old harness going into the ecu? Do I need new axles? Anything else that I need for the swap??
thanks,
-mike
So with the old harness would I have to rewire? How about the 5e harness with the 5e ecu?Tercel Drifter said:You have a 3ee. the engine you want is a 5e, direct drop in No physical mods needed your axels and even transmission are fine. you can use your old harness but I would really recommend getting the 5e ecu. Contact Dr tweak over the private messenger, He's one of most knowledgeable here on swaps. good luck.
89tercelEZ4efte said:5efe gets better mileage than the 3e.
