Hello everyone! I'm new to these forums so go easy on me
I have a 1995 Camry. Fantastic car. I have had pretty much 0 problems with it since I started driving it in 1998 (got it used). The car currently has 99,500 miles on it and I'm at a point in my life right now where I was thinking.. Should I buy a new car or just do a bigtime tuneup on my current car and ride it out for 5-6 more years..
So, considering I am going to be getting a house early next year, I decided it would be best for my wallet to just drop some money into the car I have now and ride it out for several more years. However, I have some questions for you pro's:
1) What are all the parts/fluids you guys would recommend replacing/changing/tuning in a 3rd generation camry that has had very little service in the past? I'm fairly certain the timing belt / water pump need to be changed about now, so those are two DEFINITE things I plan on getting replaced.
2) I have a slight electrical problem in the car. The lights in the area of the temperature/air control panel are out MOST of the time.. But for some odd reason, when I turn the dial they sometimes (rarely) come back on for the duration of the ride.. How much would this cost to get fixed do you think? (I'm assuming because it's an electrical problem, going to cost a lot to fix and will probably not be worth it.)
3) The car has a fairly rough idle. Also on top of the rough idle, sometimes (not all the time) the car will dip very low RPM's idlling making the car very shaky.. (Years ago it had to be taken in for service because the car was actually STALLING at idle from the low RPM's.)
4) A friend of mine in chicago is actually very familiar with toyotas and is willing to help me replace/change anything in the car within reason (not the timing belt/water pump because they are too hard to get to with the stuff he has available in his garage). So if labor costs are usually an issue with certain things that are within reason to get to, I can cut those out.
I am willing to spend a good amount of money on the car to keep me going for many more years. I do not put many miles on the car as I pretty much just drive to/from work every day which is a very short drive (2-3 miles).
Also, what are my options with installing a new audio system in the car? Anyone have any recommendations for recievers/speakers? I currently just have all the stock stuff that was in the car from day 1.
Sorry for the long post and thanks for any help you can provide!!
Adam
Adam
