I'm thinking of getting an HKS airfilter for my 95 Corolla. It's cheaper than the K&N one, but is it as good? And generally, are aftermarket filters on a stock intake worth it?
Which is crap. The actual thing is, that the oil from the filters will come off and mess up the hot wire MAF, a AFM and MAP wont really be affected. Fibers have nothing to do with that thing and it was started by VW/AUDI guys who's cars had to be repaired because of the oil problem.fibers from aftermarket filters tend to come off and mess up the MAF
Well it wont matter, the suction of the engine will suck the oils residue even though you let it sit, because the oil itself wont dry up.You should probably let it sit for a few hours after oiling it
Those are the two types of sensors to determine how much air is being and needs to be let into the engine to achieve the desired 14.7:1 air/fuel mix.Ukrainian102 said:What are AFM and MAP?
