1 - 2 of 2 Posts
I have a 95 Toyota XLS I can't get my brakes to pop up change the power booster and the master cylinder I still nothing is there a fuse for this
'00 4 Cyl. Auto Camry LE
No - but fluid leak(s) in the brake system, air in the brake system, an incorrectly installed, adjusted, or failed brake component (e.g. brake pads / shoes, a failed brake cylinder), an incorrectly adjusted Master Cylinder push rod, or a failed MC ... are all possible causes of this.
Suggest reviewing all work, checking all lines, calipers, wheel cylinders, and bleeder screws for any leaks, re-priming the Master Cylinder, and doing a full (4 wheel) brake bleed procedure.. to start. * If the Master Cylinder was removed / replaced: it may take several attempts to fully purge all air from the system - try bleeding the brakes again.
1 - 2 of 2 Posts
