Hey everyone first post here. I am having an issue with my 1996 Camry 4 cylinder engine. I just replaced the radiator and thermostat. (I did put the therm in boiling water and it opened). I transferred the fans and the coolant sensor from the old radiator which was working fine except for a crack at the top. *I've never seen the temp gauge on the car go above halfway.
So after everything is back on the car, the fans and coolant sensor are plugged in I start the car. It warms up pretty quick but the temp gauge doesn't stop going up. The upper radiator hose gets hot, the lower hose does not. I turn the car off before the temp gauge gets too high. Also note that the engine isn't very hot to the touch at this point.
I "burped" the system, hard wired the fans and even put the old therm back in, still no luck.
Any help would be greatly appreciated!!
