1 - 2 of 2 Posts
How long do I have to change the fuel filter for 96 v6 camry, I can't find it in the services manual or anywhere. They cost around
$ 50 - $60 to replace thru. dealer i change them before. and also about the engine light on, some people reply here say it might be the O2 sencer how much are they if that is the case ? because I have the same problem, the engin light goes on and I reset it and few days later it on again.
Thanks
96 Camry Coupe
How many km do you have on your cam? I change mine every 60K. If you keep getting an engine light, you need to pull the code before you start guessing what the problem may be.
1 - 2 of 2 Posts
