I was out driving the Camry today and decided to roll the windows down. Well i went to roll my back ones up first and i i started with the right one. It went up just fine. Then the left one would not roll up with the master switch, so i used the switch on the back seat driver's side door...it worked.
So i rolled it back down and tried again with the master switch (on the driver's side that controls all of the windows. It rolled down with the master switch but would not roll up.) I then rolled the driver window up and it would not roll up. Now, none of the windows will roll up or down (both on the driver side are down while the others are still rolled up (tried to roll them down but they wouldnt.
I tried the power door locks as well... neither one on either side would work. I tried to lock my doors with my key and they wouldnt work either.
Does this sound like a fuse problem? Or relay problem? How can i fix this?
-Andrew
-Andrew
