1 - 2 of 2 Posts
I have a 97 Camry XLE with 40k miles. There is a thumping noise from the right front whenever I hit bumps.
After having it checked I was told that it needed front strut mounts.
When they gave me the quote it was to replace
mounts & bearings
struts assembly
alignment
All for $600.
After doing some checking I found that this seems to be a common problem but everyone has a different take on it. Some said they just change the mounts and leave everything else alone.
The car rides fine other than the thumping so my questiona are :
1. Do I really need to change the struts (shocks)
2. Do I need to change the bearings with the mounts (some people said yes some said no)
I just want to be sure that I am not replacing things just because one shop said I needed to.
Lastly is this a difficult job to do on ones one, I have advanced mechanical skills?
Thanks for your help
· Gen 4 XLE v6
02 Toy Solara V6 MT
I'm on my third setr of front strut assemblies...all thanks to extended warranty. GO to toyota dealership and see if these TSB's apply to you vin:
PG027-02 Steering/Suspension - Ball Joint Inspection
SU001-00 Suspension - Front Support Change Reduces Noise
SU003-98 Suspension - Groans From Front Driving Over Bumps
SU00796 Suspension - Rattle/Popping Noise From Front
If i were you i'd get these checked before dishing out my personal mulla for the stut assemblies...
1 - 2 of 2 Posts
