1 - 6 of 6 Posts
i have a camry 97 v6 model with 100k miles.
For the first time, i am having starting problems yesterday in the parking lot.
I started the car and then after the needle on the RPM hit 1 , it slowly went all the way to 0 and died. It happened 3 times and and i tried the 4th time , i managed to get on the freeway and drive home. Again the same happened at home.
What can be the reason, the "check engine light is also NOT lighted up.
i have already replaced the EGR valve, done engine flush , transmission flushes, changed timing belt., spark plugs have never been replaced and the last time at 90k the mechanic said it was ok,
What could be the reason ? should i just check at autozone first
Thanks
2010 Camry SE V6
2005 Avalon Limited
probably your MAF sensor. I unplugged mine on my 05 Camry for shits and giggles once, the car stalled right out.
ASE Master, now Realtor
A 1989 Camry
:thumbup:
Do the procedure for cleaning the IAC.
Have AZ pull the codes for thoroughness.
07 XLE Camry
the car wouldnt stay on
my car starts without it but dies 1 second after on
try cleaning your TB IAC
maybe fuel pump????
1 - 6 of 6 Posts
