1 - 2 of 2 Posts
The driver's side window was operating erratically. Sometimes it would work, sometimes not, and sometimes it would work when you alternately pressed up and down on the switch a couple of times.
I guessed it was the switch, and not the motor. When I took out the master switch panel, all the other windows and power door locks stopped working.
I replaced the master switch panel with a used one, which the yard assured me was working when they pulled it (part is guaranteed), but still nothing works. I know its possible that the replacement is faulty, but I want to check other possibilities before returning the panel.
Can anyone please tell me where the fuse(s) or relays for the windows are? I've checked all five fuse boxes, but I don't see anything labeled for the windows.
Also, any other suggestions would be highly appreciated.
TIA,
JK
1 - 2 of 2 Posts
