1 - 9 of 9 Posts
1998 camry, 4 cylinder. This will only happen once the car has been driven for a little bit, and in stop & go kind of traffic. Car will come to a stop at a light, and die right away, or die once you lightly try to accelerate.
· イリジウム
And if you shift into neutral while it's doing this? Would lightly tapping on the gas pedal help?
It struggles for a few seconds, rpms go up and down, then dies. Oil light came on one time after it died, but just noticed that the last time it died. Checked the oil level before re-starting, and oil level was good.
I had the same problem-change spark plugs, add sea foam (watch video on you tube before adding). That should do it _if it doesnt clean throttle body, then clean the EGR valve. But first I would change spark plugs if they havent been changed in a while.
1 - 9 of 9 Posts
