1 - 9 of 9 Posts
Discussion Starter · #3 ·
lol
is that the only answer to the question?
forget that
as long as my fuel cut off is working its all good
how about reseting it... ?
i dunno:confused:
Highlander
Reiterating what TtT said, "Get a new one." There isn't a resettable feature on the ECU, it doesn't have DIP-packaged ICs seated on sockets that you can take out and reset them. These are all surface-mounted ICs which are probably hermetically sealed. Plus, where are you going to get a Toyota proprietary schematic of the ECU?
In fact there are a few companies specialised in testing / repairing ecu's (there about 2 or 3 in the United Kingdom, perhaps in the US ?)
Instead of buying a new one, Id' go for a used one, I don't even want to think of how much it would cost.
As for installing it, you can really easily do it yourself. It is located behind the glove box, you'll have to unplug it and plug the new one in, and that's it !
BTW are you really sure the problem is with the ecu ?
Discussion Starter · #7 ·
im pretty sure its the ecu...
my alarm goes off at random moments
my back right light is out... not the brake light
and i did change the bulb
my interior light dosnt turn on anymore
Highlander
It sounds more like an alarm problem. Having the rear lights out has nothing to do with the ECU, let alone any lights. Better check out the alarm. Sometimes if the alarm is draining the battery supply, it's possible that these electrical mishaps can occur also.
I agree. This obviously doesn't have anything to do with the ecu (fortunately !). This is only a problem with your alarm or electrical system. It might also be several different electrical problems
1 - 9 of 9 Posts
