1 - 5 of 5 Posts
Folks,
The rear panel on the drivers side between the fuel lid and the tail light is badly damaged. Is this a swappable part like the front fender, or do I have to get sheet metal work done at the body shop?
Thanks.
It would help if you can post a pic of the damage.
You might be able to pound it out but if you have much damage you will have to cut it off and weld a new quater panel on.
Or in computer terms a "Cut and Paste"
uʍop-ǝpısdn
A good auto body shop will either reshape the panel or like said above, cut and weld a new section in. How badly were you hit? Did it compromise the frame of the car? Your alignment might be permanently altered.
Resident asshole
Corolla
Well do you see any screws there? I sure didnt, no its not a swappable part, you have to cut and weld. If its not bad you can have the panel pulled out.
1 - 5 of 5 Posts
