1 - 10 of 10 Posts
my mom blew 3 holes in the engine block. now i need a replacement. i know that the highlander, Sienna, Camry, Avalon and ES share the same engine, but, if i were to replace the 1mz from a jdm one or from a different model car (as mentioned above).............................is it a direct bolt on? difference in sensors, wire harness, vac lines, etc?
TIA.
engineer in training
The 1mz is an obd 2 engine, you need to match it up with another obd 2 engine... Im not a 1mz person... I dont know if the 97+ have egr or not, but if they do JDM engines do not have egr so thats a check engine light and an instant fail on an inspection. So i think you should be looking at pretty much any 97+ v6 to swap in, that should work.
Sorry she blew the engine, didnt change the oil? :( anyway best of luck!
TN Pussy Man
Camry
your best bet is to just pick up a 1mz from another gen4 camry and keep it simple, then there would be no question
most 1mzs that you find will be from a gen4 camry anyway
TN Pussy Man
Camry
no, the 3mz will fit pretty much for sure
take a look at the gen5 camry 1mz vs the 3mz- I'm presuming that they still mount the same way, or else they would have to make some major changes to put them in
but again, I've never had the chance to see how a 3mz looks in the gen5 yet, so I'm just making a logical assumption
but then it's also about wiring harness and ecu, along with little things such as egr, exhaust system and intake, which are fairly simple in comparison to hte wiring job into a gen4 or 3 even
1 - 10 of 10 Posts
