My 99 4Runner Engine Light keeps coming on. The only thing I've noticed is that it seems to come on after the fuel gauge shows half full. After checking as much of the wiring for any loose connections, making sure the gas cap was tight, I'm not sure what else to do. If I fill the tank up the engine light will go out within about 5km.
I've been told that I should check the MAF sensor and possibly clean it, but I don't see what that has to do with the fuel gauge.
I don't have a BR-3 OBDII systems analyzer or the windows software to check what the error code is. I live in Burlington, Ontario anyone close have one?
Once I figure out what the problem is I've read I can un-hook the battery to reset the codes, but I've also been told that by un-hooking the battery on some cars with air bags you permanently disable the air bags. Someone else mentioned just pulling the EFI fuse to reset the codes.
Anyways I need to figure out what the problem is first.
