Hello all,
Please check my signature block for specifics on my Camry.
The problem started suddenly when the car had 62K miles on it. It had been sitting in the garage for a week when my wife tried to start it. She said it would not start for a while, it would just crank. When it finally started, she said it backfired pretty bad and the engine started making a loud knocking noise as it idled. She shut it down immediately. I suspect she was depressing the accelerator pedal when she was trying to start it. Even though she has not driven a car with a carburetor for many years, she still seems to have a hard time keeping her right foot on the floor when starting a car with fuel injection. Makes me crazy!
Anyway, I started the car up that evening and noticed a knocking noise that had never been there before. Since I had checked the valve clearances just a few thousand miles before this event, I pulled off the valve cover and looked everything over.....everything was fine.
The next thing I tried was a few bottles of Techron. No help.
The next thing I tried was a check of the EGR valve. Everything checked out fine.
I next tried to steth the engine. I don't have a real good mechanic's ear, but the noise definitely seemed to be coming from the top end. I stethed the oil pan and the lower part of the engine block and couldn't hear the knock much at all at these places.
The next thing I did was to buy a new knock sensor (mucho $$) and put that in. No help.
The next thing I did was to take it into a Toyota dealer. They did some load tests by pulling spark plug caps off one-by-one and said it did not seem to be a rod knock. They then ran some top end cleaner through it. Cost me $100 and did not help.
I then sucked lots of Sea Foam thru the engine via the brake booster hose. I even stuffed a Sea Foam soaked rope into a few of the cylinders and let it set there for a few days to dissolve any deposits. No help.
The next thing I tried was to pull off the exhaust manifold, check it out for cracks and such, and reinstall it using a new gasket. No help.
The next thing I tried was a tank of premium gas. No help.
The next thing I tried was a new timing belt and new pulleys. No help.
The next thing I tried was to send out this post and plea for help.
I'm bummin'. You can hear the noise when you start the car. It is a metallic sounding knock, sounds like it is somewhere in the top end. My Dad is a pretty experienced mechanic and says it sounds like piston slap. I can't imagine that this is what it could be. Remember, the engine started making this noise suddenly, after the big backfire (see above). The noise can be heard from the street as my wife drives the car away. I've noticed that when I'm driving it, the noise seems to go away above 3000 RPM and is most pronounced at low RPMs, especially during acceleration and going up hills. It gets a little quieter when the engine is warm, but not much.
I've changed the oil religiously every 3000 miles in this car. When I pull off the valve cover, it is very clean with no hint of sludge.
I'm at wit's end. I'm thinking seriously of throwing my hand up in disgust, purchasing towing insurance, and runnin' 'er till she blows!
Any assistance would be greatly appreciated.
