You have to take off the door panel. There will be some screws along the lower edge of the door. There should also be some screws like in the door handle and armrest that you will have to find and remove. On the side of the door there will be an anchor screw that will need to be popped out. Once you have all the screws out you will have to pull on the panel, you will feel the clips pop. Once you have the panel loose you will have to roll down the window and pull up on the entire panel till it pops up. Also you will have to remove the power windows and lock panels. This is how it is on my camry, it should be pretty much the same way.
